Daimler-Merceds D.III
gastec
Auckland, New Zealand
KitMaker: 947 posts
AeroScale: 46 posts
Posted: Friday, October 26, 2018 - 04:35 PM UTC
Managed to throw this little powerplant together in a day. Wingnut Wings 1/32 (From a Roland D.VIa) with spark plugs and valve springs from Taurus models. Additional detals adde using fuse and speaker wire. Painted with acrylics and laquers and weathered with oils, washes and pigments...
ColinEdm
KitMaker: 1,206 posts
AeroScale: 62 posts
Posted: Saturday, October 27, 2018 - 12:02 AM UTC
Wow! Beautiful job Gary, looks like you could fire it right up! I amd wanting to do a WWI kit with the exposed engine more and more seeing work like this.
Vicious
KitMaker: 1,336 posts
AeroScale: 70 posts
Posted: Saturday, October 27, 2018 - 09:57 AM UTC
Very Nice!....i am doing the same motor just waiting for same parts from Taurus
KitMaker: 766 posts
AeroScale: 758 posts
Posted: Saturday, October 27, 2018 - 11:22 AM UTC
Bravo - very nice.
MerlinV
KitMaker: 606 posts
AeroScale: 600 posts
Posted: Sunday, October 28, 2018 - 06:48 PM UTC
Wow!
Love the metallic effects... The copper and the rust on the exhaust!
Great job!
Hugh
Szmann
Netherlands Antilles
KitMaker: 1,255 posts
AeroScale: 290 posts
Posted: Sunday, October 28, 2018 - 09:04 PM UTC
Gary, that level of detail is plainly insane! Loved it!
Gabriel
Louis
Bas-Rhin, France
KitMaker: 437 posts
AeroScale: 436 posts
Posted: Monday, October 29, 2018 - 03:47 AM UTC
Beautiful !!!
Tell us a little about the steps to paint the exhaust ?
I would like mine to be like that
Regards
KitMaker: 11,641 posts
AeroScale: 10,983 posts
Posted: Wednesday, November 14, 2018 - 11:52 PM UTC
Beautiful
KitMaker: 17,031 posts
AeroScale: 12,617 posts
Posted: Friday, November 16, 2018 - 08:46 AM UTC
Hi Gary
Simply magnificent! That must rate among the best - if not the best - model engines I've ever seen! If you said it was 1:4 or 1:8 scale I'd have believed you.
As has been noted, the effects on the exhaust are amazing. Could you write a "How To" article for Aeroscale on the basics of how you tackle a finish like that?
gastec
KitMaker: 947 posts
AeroScale: 46 posts
Posted: Sunday, November 18, 2018 - 09:06 AM UTC
Thanks guys
Process is very straightforward. After hollowing out the outlet to make the 'walls' more to scale, I sprayed a basecoat of Modelmaster Lacquer exhaust. Once dry, this was buffed to a sheen so it represented real steel. I then misted over a light and very diluted coat of Mig medium rust wash. Before this starts to dry, i then apply pigment. Using an old brush, i pick up some rust pigment and stipple it onto the exhaust. The wash will absorb the pigment, but by careful application, you can acheive the effect as above. Soot pigment is applied to the outlet. Plenty here as fuel quality was really poor in those days. A final coat of pigment sealer fixes everything in place.
Pretty simple process.
KitMaker: 1,600 posts
AeroScale: 1,449 posts
Posted: Sunday, November 18, 2018 - 11:03 AM UTC
How the hell did you manage to get the plastic so uniformly thin? It must have been fairly hard to get it to that point without it collapsing in when you were working on it? I originally thought it was a galvanically grown replacement set from moskit or some such just makes the result even more astounding. It looks so life like awesome work there Gary!
krow113
KitMaker: 460 posts
AeroScale: 96 posts
Posted: Sunday, November 18, 2018 - 12:50 PM UTC
Nicely done!
Pretty sure you have the exhaust on backwards.
gastec
KitMaker: 947 posts
AeroScale: 46 posts
Posted: Sunday, November 18, 2018 - 01:18 PM UTC
Thanks Chris. A lot of patience and a very sharp blade.
Steve. Will only fit one way.
Vicious
AeroScale: 70 posts
Posted: Sunday, November 18, 2018 - 01:34 PM UTC
Nicely done!
No,the Roland have the exhaust like that,the Albatros have the same motor and exhaust but on the other direction
I love the exhaust i have to copy your technique on my Albatros,you use only the spring from Taurus or also the timing e lifters?
gastec
KitMaker: 947 posts
AeroScale: 46 posts
Posted: Monday, November 19, 2018 - 08:31 PM UTC
Just the springs.
