OFFICIAL: Vietnam War 50 Campaign
KitMaker: 644 posts
AeroScale: 600 posts
Posted: Monday, April 16, 2018 - 07:47 PM UTC
Naseby: Excellent work on the cockpit. It looks great!
Alliedbuilder: Very nice Skyraider! Congrats!
Klaus-Adler: Nice progess on those figures!
Bob: Will You go for a Navy Skyraider?
On my Skyhawk, I put some more plumbing work into the already nicely molded wheel wells.
The fit of the Fujimi Skyhawk is a bit fiddly, as Fujimi made moduls for several Skyhawk versions.
After the primer revealed no major issues, I started with painting.
I have not counted how often I broke off the small slat fittings but, it must have been five times already .
After sealing and decaling, a dark wash of oil color was applied.
Now, off for some more weathering!
KitMaker: 4,814 posts
AeroScale: 2,616 posts
Posted: Monday, April 16, 2018 - 08:04 PM UTC
Oliver, your A4 is really looking nice. I keep looking for a 1/48 kit, but the prices scare me away.
The A-1 will be in Airforce SEA scheme.
LinusB
KitMaker: 247 posts
AeroScale: 105 posts
Posted: Tuesday, April 17, 2018 - 05:25 AM UTC
Just a quick question, on reading the Campaign outline is this restricted to aircraft only?
KitMaker: 3,639 posts
AeroScale: 2,660 posts
Posted: Tuesday, April 17, 2018 - 08:53 AM UTC
Linus,
No, it is not. It's pretty wide open. What did you have in mind?
LinusB
KitMaker: 247 posts
Posted: Tuesday, April 17, 2018 - 06:41 PM UTC
Linus,
Cool. I have Tamiya’s M107 self propelled gun sitting around I thought I might enter.
Posted: Tuesday, April 17, 2018 - 08:28 PM UTC
That will do nicely, welcome aboard!
Naseby
Slovakia
KitMaker: 819 posts
AeroScale: 470 posts
Posted: Wednesday, April 18, 2018 - 01:08 AM UTC
@ Oliver - cool looking A-4 there.
@Bob - Athou the 1/48 Skyhawk from Hasegawa is pricy, its the best kit out there - worth every cent.
LinusB
KitMaker: 247 posts
Posted: Thursday, April 19, 2018 - 04:38 AM UTC
Hi all such nice work going on. I really do like that A4 Oliver.
Here is my non-winged entry. Tamiya's partly retooled and reboxed Italeri M107.
RhinoSpit
Bas-Rhin, France
KitMaker: 205 posts
AeroScale: 176 posts
Posted: Friday, April 20, 2018 - 11:37 PM UTC
I've started yesterday the french KI-43 III oscar.
Naseby
Slovakia
KitMaker: 819 posts
Posted: Saturday, April 21, 2018 - 01:28 AM UTC
@ Franck : You have realy made an unconventional choise of subject and a very interesting one. The French - British - Japanese "relationship triangle" in Indochina is something that dont gets portraited in plastic too much.
Posted: Saturday, April 21, 2018 - 01:44 AM UTC
@ Franck, I will follow your Ki43 to see what scheme you use. Cannot wait.
@ Oliver, really cool looking A-4 there. Cannot wait for the finish. I love the A4, but the kits are so expensive.
@ Linus, nice choice. I did not know there was a kit for the M107, but I am not an expert in armor.
LinusB
KitMaker: 247 posts
Posted: Tuesday, April 24, 2018 - 05:38 AM UTC
This is one big gun.
Posted: Tuesday, April 24, 2018 - 12:46 PM UTC
Wow you're not kidding Linus with it stuck up like that you could lose an eye if you're not careful!
Torpon
Spain / España
KitMaker: 74 posts
AeroScale: 73 posts
Posted: Wednesday, April 25, 2018 - 01:06 AM UTC
Hi everyone!
I am a bit late to the party but here is my entry. Academy 1/48 F-4C Phantom II
I started timidly this weekend trying to remove the seam from the canopy. What a mess! Normally takes me longer to make a serious mistake. I'll try to get Pledge tomorrow. Any advise?
RadekZ
Warszawa, Poland
KitMaker: 125 posts
AeroScale: 85 posts
Posted: Wednesday, April 25, 2018 - 03:43 AM UTC
@Oliver - crazy job with detailing Skyhawk:) I probably wouldn't dare to try it even in 1/32
@Linus - good progress, but it seems you need a bigger room for this barrel
@Franck - what an unusual subject! Cockpit & engine look good.
@Carlos - I can't wait to see progress. This kit is on my "to buy" list
Now a short update on A-7D.
I managed to clean bad seam mark on canopy. It looks acceptable now . Apart of this a short but steady progress. A very simple cockpit is assembled and fuselage is now sealed:
Now all-favourite part of hobby awaits me ... filler and sanding
Radek
Posted: Wednesday, April 25, 2018 - 05:59 AM UTC
Carlos I've used a number of things to smooth out an oopsie on a canopy but the best I've found is really fine, and by fine I mean really fine 1200 grit and up, sanding mesh or sand paper (wet and dry used in panel beating) for best results use it wet stops the paper clogging with plastic.
Torpon
Spain / España
KitMaker: 74 posts
AeroScale: 73 posts
Posted: Wednesday, April 25, 2018 - 04:14 PM UTC
Radek, A-7D interior looking great. How is your canopy going?
Chris, thanks for advise. I kind of did it, perhaps I should have persisted a bit more but I ended up with the canopy being a big cloudy. I read somewhere that a dip in Future or similar would make canopy shiny again. I used Aqua Gloss but the result was not good at all. (I am a bit temperamental and I chuck the Aqua gloss in the bin after the second attempt.) I removed Aqua gloss and sand again (micromesh set ) and now I have my slightly cloudy canopy back.
Do you guys use Pledge or similar to make canopies super shiny or polishing compounds or simply careful sanding? Can anyone recommend a nice product that I can get in the UK?
If not I will persist with the sanding...
Thanks,
Carlos.
Posted: Wednesday, April 25, 2018 - 10:12 PM UTC
Carlos, after I clean the plastic and let dry I will dip the canopy and clear parts into Future then using tweezers I will lay the parts on some paper towel cover with a large enough bowl or anything that will keep dust from alighting on the future and let dry for at least an hour if not more. This is done before any building, painting, or other Assembly.
After dry for a day the canopies are easy to handle, tape, glue, or cover with tape then cut to allow the frame to show when paining.
KitMaker: 4,649 posts
AeroScale: 3,001 posts
Posted: Thursday, April 26, 2018 - 12:42 AM UTC
Carlos, it looks like they changed the product naming again, I thought it was Pledge Multi Floor Finish, now it's Pledge Floor Gloss. Past hola!, my Spanish is non existent, but it doesn't look like they carry a similar product on their Spanish site.
I have had good success in using ever finer grits of sanding pads to clean up a canopy. But, up to 8,000 grit it all still looks cloudy, the 12,000 grit turns it shiny. Try alternating sanding directions as you change grits. Left to right for one grit, top to bottom for the next grit. That way the sanding scratches get broken down as you get finer.
Novus also has a plastic polishing set out there somewhere that could help.
RadekZ
Warszawa, Poland
KitMaker: 125 posts
AeroScale: 85 posts
Posted: Thursday, April 26, 2018 - 03:20 AM UTC
Thanks,
Carlos.
It looks good, Carlos. Molding line is gone.
On th pic you can still see some part of it on the frame (I'll clean that one later after assembly.
Radek
Torpon
Spain / España
KitMaker: 74 posts
AeroScale: 73 posts
Posted: Thursday, April 26, 2018 - 02:08 PM UTC
Bob, Mark, thanks for the recommendations. I am living now in the UK and I got yesterday Pledge floor gloss. I have been all these years without Future/Klear secretly wanting to have one bottle in my stash...
Unfortunately I went to the pub after work last night and I was feeling a bit delicate by the time I went home as to try it. Tonight is the night! I will let you know how it goes.
Radek, that looks perfect! I have the feeling I should have similar results now if I wouldn't have been playing trying to smooth out the Aqua Gloss varnish in the inside of the canopy.
RadekZ
Warszawa, Poland
KitMaker: 125 posts
AeroScale: 85 posts
Posted: Thursday, April 26, 2018 - 04:47 PM UTC
Going to pub doesn't sound unfortunate... well until you remember how you returned home
I've tried "excercising" with varnishes on canopy while building Buffalo for PTO campaign. It almost costed me a model . Good thing is I achieved very satisfactory results in removing gloss varnish with Gunze's Levelling thinner and isoprophyl alcohol (but it was Tamiya Gloss varnish).
Radek
Lakota
#123
New Mexico, United States
KitMaker: 1,133 posts
AeroScale: 265 posts
Posted: Saturday, April 28, 2018 - 08:48 PM UTC
Howdy Y'all
I haven't had time to start an airplane I wanted to build. As time is winding down I will enter a figure.
This is Verlinden's 1/35 US Seal figure. The other figure is for the "Stand Bold" campaign.
I bought this kit at a swap meet years ago and am happy I get to use it.
Let me know if you have any questions.
Thank you,
Don "Lakota"
Naseby
Slovakia
KitMaker: 819 posts
Posted: Sunday, April 29, 2018 - 05:52 PM UTC
@ RadekZ : Nice progress on the A-7, cant wait to see the camouflage on it.
@ Carlos : now thats some courage right there with the F-4. I have one the stash but for me thats more like a 6-months project
Torpon
Spain / España
KitMaker: 74 posts
AeroScale: 73 posts
Posted: Monday, April 30, 2018 - 01:47 PM UTC
I am starting to get worried, I am in the middle of week two and I haven't finished the cockpit yet, and the box is still full of plastic.
I am stuck now with a seam inside the air intake. Classical one that I couldn't see very well on plastic but it does stand out when painted in glossy white. I can sand it from the outside so tonight it will be mine!
Carlos.
