1/48 Grumman F6F-3 Hellcat (Eduard)
Venko555
Bulgaria
KitMaker: 872 posts
AeroScale: 204 posts
Posted: Saturday, December 24, 2016 - 09:10 PM UTC
Joel, thank you for the tip!
I will have to spray one or two light coats more to blend some areas. And I broke the Pitot tube, so have to make new one
Nice improvements with your Wildcat too, very nice, can't wait for the painting
V
KitMaker: 9,688 posts
AeroScale: 7,313 posts
Posted: Saturday, December 24, 2016 - 08:22 PM UTC
Venelin.
Your free hand camo paint scheme really came out quite well.
One suggestion for your next paint scheme, try the black basing technique. Using light coats of paint you'll be surprised at how well it weathers those color coats without having to do anything for the basics. Then you tweak it to where you want it to be.
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Saturday, December 24, 2016 - 02:19 PM UTC
Merry Christmas!
Had some time for spraying the camo freehand
I will enhance some areas a bit, but later
Best wishes,
Venelin
Posted: Thursday, December 22, 2016 - 10:45 PM UTC
Grumman actually used their standard Grumman Gray as a primer on the F4F Wildcats and approx. the 1st 100 or so F6F-3 Hellcats. Once they used up what stocks of Grumman Gray they had, the switch was made to YZC as a primer coat.
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Thursday, December 22, 2016 - 03:31 PM UTC
Which primer is applied on the outer surfaces-fuselage and wings? Interior green, ZCY, or bare aluminium?
I'm asking this, because I want to do a very small amount of chipping, and not sure of the color.
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Wednesday, December 21, 2016 - 05:33 PM UTC
Primer Surfacer 1500
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Tuesday, December 20, 2016 - 03:00 PM UTC
Main assembly is done, no problems at all. Only a small filling was needed at one spot at the tail, but it's my fault. I wanted to try the new putty from Mr.Hobby here-it's very useful for small filling, semi-liquid, like toothpaste.
Also added the exhausts, you have to drill them for more realistic look
Regards!
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Monday, December 19, 2016 - 12:04 PM UTC
The seat is a bit on the thick side (like armored ) , but I decided not to add much aftermarket here, Ultracast has very nice resin seats though.
Venelin
Posted: Sunday, December 18, 2016 - 10:09 PM UTC
Joel, thank you for the info!
The paint I used is close enough to FS 36440 for me
Venelin
Venelin,
That's the most important thing.
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Sunday, December 18, 2016 - 09:44 PM UTC
Venelin
Posted: Sunday, December 18, 2016 - 08:30 PM UTC
Venelin,
All Grumman aircraft made during the war at the Bethpage Plants had the interior of the cowl painted Grumman Gray. The actual color was made right here on Long Island and back then there was no ANA number for it. The best match as by the leading experts (certainly not me by any means) is FS36440. One or two shades one way or the other is no big deal.
If you're modeling a Grumman aircraft not made at the Bethpage plant but by a contracted aircraft company, then YZC was the accepted color.
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Sunday, December 18, 2016 - 02:33 PM UTC
Next, assembling the fuselage-no problems here. You have to be careful with the side windows though.
Engine cover is not glued to fuselage yet, only test fit. For the inside color of the cover there are three options, according to this reference:
http://www.ipmsstockholm.org/magazine/2004/05/stuff_eng_interior_colours_us_part3.htm
I chose Grumman grey, instead of Interior green or Zinc chrome, paint is Light grey from Gunze. The cover of the crankshaft is darker grey.
Posted: Saturday, December 17, 2016 - 10:02 PM UTC
Venelin,
Nice job on those .50 cal. MGs. Once drilled out they certainly do look the part. I did use the Master Brass machined .303s on my Mossie, and the level of detail was something I just wasn't expecting.
CMOT
KitMaker: 10,572 posts
AeroScale: 265 posts
Posted: Saturday, December 17, 2016 - 01:53 PM UTC
I like your progress so far and I am waiting on the Master barrels to arrive before starting mine. I will be watching this build progress and looking for some tips during the journey.
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Saturday, December 17, 2016 - 01:32 PM UTC
Improving the Brownings as much as its possible, of course Master barrels are better, but I like the result with these. Black Surfacer 1500 for the base paint, then polishing with AK steel pigment for metallic shine:
KitMaker: 6,739 posts
AeroScale: 6,147 posts
Posted: Saturday, December 17, 2016 - 07:11 AM UTC
Nice start , just might be the right inspiration I need to finish Eduards -5 late version that ended up being a shelf queen
Looking forward to your next up-date .
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Friday, December 16, 2016 - 09:29 PM UTC
Hi, Joel
The seatbelts are PE from the frets-the hardest work for me yet . You're right that the fabric belts looks better, although I haven't tried them, but in the future will use the latter instead.
Posted: Friday, December 16, 2016 - 08:59 PM UTC
Venelin,
Very nice job on finishing the engine. I must say that Eduard's 1/48 engines are the equal to Tamiya's in everyway.
And the cockpit really looks quite nice as well. What stands out for me is the seatbelts and Harnesses. They really look great. Are they Eduard's cloth belts and PE buckles? They certainly look so much better then their PE ones.
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Friday, December 16, 2016 - 07:13 PM UTC
Proceeding with cockpit and engine. The engine is painted Chrome silver metallic from Gunze, and weathered with AK stuff. Some oils will be applied on the cockpit before closing in the fuselage.
Posted: Friday, December 16, 2016 - 12:07 AM UTC
I believe Darren is actually correct here.
VF-27 came up with the "Hell Cat" art while at Hawaii in the Spring of '44 as a means of improving morale among the pilots. Non-academy pilots were typically assigned to escort carriers while the big fleet carrier squadrons typically were home to the naval academy pilots who viewed themselves as better aviators. Princeton's VF-27 actually had the best kill ratio of all escort carrier squadrons, however when the ship was sunk off of the Philippines the surviving planes were absorbed into the fleet carriers and promptly lost their unauthorized nose art.
Early examples feature the bloodshot eyes, later ones typically lack it. There are a few later examples of it on all over GSB aircraft, such as the famous shot of Paper Doll.
Paul,
Thanks so much for the information. I never would have guessed it was true, since the Nickname for the F6F was the 2nd Cat aircraft from Grumman's.
bomber14
KitMaker: 261 posts
AeroScale: 243 posts
Posted: Thursday, December 15, 2016 - 06:54 PM UTC
Thank you for joining with comments!
I assumed the artwork in the nose resembles a shark mouth in the beginning (because of the teeth maybe), but now it's seems more logical that it is indeed a cat mouth, as some of you pointed out-from the nickname "Hellcat" .
But in the end it's not so important for me, as long as it looks menacing and cool
venelin the kit is excelent. one of the kits i most enjoyed building. and i also have known the cowl to be a cat's mouth but either way it is a sharp addition to the plane.
joe
Removed by original poster on 12/16/16 - 13:51:05 (GMT).
Venko555
Bulgaria
KitMaker: 872 posts
Posted: Thursday, December 15, 2016 - 11:30 AM UTC
PeeJay74
#363
KitMaker: 404 posts
AeroScale: 380 posts
Posted: Thursday, December 15, 2016 - 05:36 AM UTC
Posted: Thursday, December 15, 2016 - 04:41 AM UTC
Darren,
I've never heard that before about it being a Cats mouth and eyes, so I did a few Google searches and every reference to the F6F-3s on the USS Princeton said it's supposed to be a Sharks mouth and eyes. Granted it's the weirdest sharks mouth I've ever seen, but it had a really large cowl to cover.
