1/48 P-51D Tamiya
Venko555
Bulgaria
KitMaker: 897 posts
AeroScale: 206 posts
Posted: Sunday, June 05, 2016 - 05:01 PM UTC
Thank you!
Still lot of work to do with weathering
Forgot to show the propellers:
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Monday, June 06, 2016 - 05:00 PM UTC
The reason why I have sprayed the propeller's bases in blue:
bomber14
KitMaker: 272 posts
AeroScale: 254 posts
Posted: Tuesday, June 07, 2016 - 12:28 AM UTC
LOOKS GREAT!! nice job for your first NMF build.
nice catch on the prop cuffs too. never noticed that before. never knew the cuffs were rubber sleeves either.
joe
bomber14
KitMaker: 272 posts
Posted: Tuesday, June 07, 2016 - 12:30 AM UTC
I'll have to ask my brother about the flying surfaces, but I would think that if they used aluminum dope on the wing, they did the same for the flying surfaces, as they were riveted as well.
thanks Joel. i am starting to get the itch to build one of these.
joe.
KitMaker: 10,104 posts
AeroScale: 7,347 posts
Posted: Tuesday, June 07, 2016 - 01:30 AM UTC
Venelin,
I'm really impressed with your weathering. The various NM Panels add that something extra. Same with the cuffs on the prop blades. I never gave them much thought as from what I understand, the P-51s were the only USAAF fighter to use cuff blades.
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Tuesday, June 07, 2016 - 02:22 PM UTC
I haven't seen that overspray, on the propellers cuffs, on most bluenosed P-51 models .
I'm working on the base also, it will represent landing strip with some grass on the sides.
V
bomber14
KitMaker: 272 posts
Posted: Tuesday, June 07, 2016 - 05:23 PM UTC
i guess it is just a matter of if whoever was painting the nose was "inspired" enough to mask off the blades.-lol-
joe
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Tuesday, June 07, 2016 - 09:38 PM UTC
joe
Meantime, leaving the different effects to dry, I'm working on the base. Simple picture frame 20x25cm, balsa wood for the sides and filling with insulation foam and cork.
V
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Wednesday, June 08, 2016 - 08:07 PM UTC
Landing gear is ready, when I finish with the weathering, will put the propellers
V
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Thursday, June 09, 2016 - 01:37 PM UTC
Almost done, a bit of dust, oil etc. and proceeding with the base
V
CReading
#001
KitMaker: 1,706 posts
AeroScale: 88 posts
Posted: Thursday, June 09, 2016 - 06:52 PM UTC
Very nicely done.
C.
Posted: Friday, June 10, 2016 - 07:04 PM UTC
Venelin,
The finished P-51D looks outstanding. Just the right amount of weathering, yet nothing is over done. As for the prop cuffs, once the blades were glued in place, the effect is just perfect. What a great find.
KitMaker: 6,465 posts
AeroScale: 3,507 posts
Posted: Friday, June 10, 2016 - 07:31 PM UTC
Coming together beautifully Venelin, great build!
As Joel said, the detail on those prop cuffs based on the original images is a really nice touch, one I will definitely remember.
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Friday, June 10, 2016 - 08:33 PM UTC
Thanks, glad you like it!
Forgot only the landing light, here it is
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Saturday, June 11, 2016 - 02:06 PM UTC
Wash on the wheels with mixture of AK Dust+Earth effects. Now the diamond pattern shows better:
V
spaarndammer
Noord-Holland, Netherlands
KitMaker: 1,943 posts
AeroScale: 386 posts
Posted: Saturday, June 11, 2016 - 04:14 PM UTC
Beautiful Mustang! The curve of the blue nose is sprayed very so good!
Jelger
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Tuesday, June 14, 2016 - 12:41 PM UTC
Thank you!
Only the two mirrors on the canopy remained. I decided to make them out of spare clear frame, from 1/35 Panzer . They are 2mm in diameter, which is close enough, comparing to the Tamiya Spitfire (which I have in my stash) mirror. They are same on both Mustangs and Spitfires
Well, another thing. By the Murphy law, I found in the Quickboost news for June, that they released correct propeller w/tool and spinner, for Tamiya Mustangs (they are a bit off shape).
And that when the bird is almost finished, arghhh... Maybe I will replace it, still not decided yet
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Tuesday, June 14, 2016 - 10:47 PM UTC
Progress with the base. The concrete squares are 8cm, painted with various colors, pre-shading etc., then oil dot filter with three oils-Light, Dark Grey and Buff. There will be washes and pigments after.
Soil is homemade paste from White glue/Talcum powder in ratio 1/2, mixed with Earth pigments and brown acrylic paint. I will put static grass in the end
V
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Wednesday, June 15, 2016 - 12:32 PM UTC
Wash, pigments and static grass applied on the base. Some cleaning and tough up on the frame left. The bird sits very nice, I have to put only the mirrors
Posted: Thursday, June 16, 2016 - 10:14 PM UTC
Venelin,
That's really one nice base. The perfect display for the P-51D.
KitMaker: 4,201 posts
AeroScale: 1,802 posts
Posted: Friday, June 17, 2016 - 03:02 AM UTC
Venelin,
Excellent display!
Well done,
KitMaker: 1,345 posts
AeroScale: 1,138 posts
Posted: Friday, June 17, 2016 - 10:38 PM UTC
Venelin, that's a really nice display for your pony. Everything looks just right. Congrats on your finished build!
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Saturday, June 18, 2016 - 10:57 AM UTC
Thank you very much!
I really enjoyed this build and appreciated the support!
I have put two Elf headlights 2mm, for the mirrors and now the P-51 is finished:
:-H
Venelin
GhostHawk
Cordoba, Argentina
KitMaker: 268 posts
AeroScale: 264 posts
Posted: Saturday, October 01, 2016 - 04:20 AM UTC
Hi:
Really excelent work...!!! Very inspirating...!
Thanks...
Venko555
Bulgaria
KitMaker: 897 posts
Posted: Saturday, October 01, 2016 - 12:00 PM UTC
Thank You, Diego!
Really like the P-51 and surely will make another, the new from MENG probably
Venelin
