Had a bit of bench time tonight so I continued on. Having this snap-on, no-glue feature gets the work done quickly. The fit is nice though in some cases very tight that you get the plastic strained as you put components together.
A couple of components may need to have glue on it, like the turret base.
The gun is movable up or down though I noticed there is not much play to do it. I guess a correction may be made by shaving off a bit of the top part of the shield so there's greater movement in the elevation. Anyways, it's a non-issue for me as I'm not a fan of moving parts on my builds
Till next update.
Tat
