OFFICIAL: Duel II Campaign: Engage the Enemy!
KitMaker: 3,551 posts
AeroScale: 2,583 posts
Posted: Thursday, December 31, 2015 - 05:29 AM UTC
Welcome to the Official Duel II Campaign thread! The campaign will run from January 1, 2016 through January 1, 2017.
Please post your in-progress shots and campaign discussions here.
Post your completed build photos in the campaign gallery.
If you haven't enlisted yet but want to join in, you can sign up here.
Looking forward to engaging the enemy in 2016!
Here's a list of the enlistees and their builds including partnerships:
Ah3000mk1
Aurora-7
Florence
KelticKnot: Bf 110 vs Lancaster with SGTJKJ
Lakota: F4U vs Ki-84
MichaelSatin: Mirage III vs MiG-21
panzerIV
PrickleHead: Hurricane I vs Bf 110
SGTJKJ: Bf 110 vs Lancaster with KelticKnot
By the way, here's a link to the Osprey Duel website so you can see a list of the books.
PrickleHead
KitMaker: 338 posts
AeroScale: 190 posts
Posted: Thursday, December 31, 2015 - 02:55 PM UTC
Have two kits in the pile that fit nicely into this campaign.
Posted: Thursday, December 31, 2015 - 08:08 PM UTC
My entry:
Really looking forward to this one!
KelticKnot
KitMaker: 768 posts
AeroScale: 656 posts
Posted: Friday, January 01, 2016 - 10:13 AM UTC
This will be my entry using Tamiya's monster 1/48th Lanc and probably Eduard's BF110-G4 unless someone would like to partner me for the campaign.
KitMaker: 9,743 posts
AeroScale: 3,665 posts
Posted: Friday, January 01, 2016 - 07:37 PM UTC
Paul, I would like to be your wingman - or is it adversary. I was in for the first osprey duel and I am up for this one as well.
I am in with a me 110. It will be a nightfighter, but one of the earlier versions from Eduard in 1/48.
Paul, let me know if you are up for it
Campaign administrator, a quick question: if Paul finishes and I am for some reason do not finish, Paul will still get his ribbon?
In other words if only one party in a two participant duel finishes, the finishing participant will still get the ribbon? Just to make sure
Posted: Friday, January 01, 2016 - 08:20 PM UTC
Jesper,
While I FULLY EXPECT YOU TO FINISH , you are quite correct. As long as you two are in a partnership and one of you finishes, the finisher will get the ribbon.
I'm going to try to get a list of enlistees, their proposed builds, and if they're in partnerships added to the opening post and keep it updated. So let us know what you're all up to!
KelticKnot
KitMaker: 768 posts
Posted: Friday, January 01, 2016 - 08:54 PM UTC
I'm totally up for it although I think wingman would be better! By all accounts the poor Lancasters were often sitting ducks to the nightfighter's 'jazz music'
Posted: Friday, January 01, 2016 - 09:00 PM UTC
Paul, you got yourself a wingman I believe my 110 is the early 1942 version without the Schlage music, so you are safe from the Jazz I will post pictures of my kit a little later. It is going to be fun.
Michael, thanks for the quick reply. I fully expect to finish, but just wanted to make sure
Posted: Friday, January 01, 2016 - 09:39 PM UTC
Here are the promised pictures of the Eduard Bf 110E. I am doing a NJG 1 Bf 110 in 1942. I really like the red and black shark mouth.
I will probably only start in March, but already looking forward to it
Lakota
#123
New Mexico, United States
KitMaker: 1,058 posts
AeroScale: 251 posts
Posted: Sunday, January 03, 2016 - 02:46 AM UTC
Howdy Y'all
Here's my entry for a Duel Book to be released this spring.
I'll use the Academy 1/72 F4U-1 Corsair and the Hasegawa Ki-84 'Frank'.
Take care,
Don "Lakota"
Posted: Sunday, January 03, 2016 - 05:39 AM UTC
The story so far, the Italeri 1/32 Mirage IIIC.
The kit instrument panel is the wrong configuration (for the Israeli Mirage anyway.) It also has no instruments, just blank depressed circles. I decided to leave the config alone but added some instruments from an old Monogram instrument sheet:
Here's the cockpit built up:
Nose gear bay:
The landing light in the nose is just a hole with a clear cover. I made a small light bay with a piece of tube and a clear part from the kit. The kit has lights mounted on the nose gear leg which is incorrect for the IIIC so I used one of the lenses here:
And here's the nose gear bay mounted in the lower fuselage:
And the cockpit:
I was seriously wound up when this one came out, I've always loved the Mirage. Unfortunately, I was working on the Tamiya Mossie when I got hold of this and, frankly, it sort of suffers in comparison. Still, while definitely not as sharply detailed or well engineered as the Mosquito, this is a nice kit and I'm really happy to have it.
Sadly it's back to work tomorrow so progress should slow down substantially.
Removed by original poster on 01/04/16 - 00:42:30 (GMT).
Posted: Sunday, January 03, 2016 - 01:04 PM UTC
Nice start, Michael. Detail looks a bit soft, but at least it is there in the first place.
It will be an awesome duel - especially in this scale.
Posted: Sunday, January 10, 2016 - 05:11 AM UTC
Thanks Jesper!
Making progress on the Mirage, but not without some battles (it IS Italeri, after all).
Here's a main wheel well:
The inner and outer halves aren't glued together yet but, well, read on.
How the intake trunks should look (instructions not very clear):
Inside the engine halves:
Don't get rid of that small flange at the aft end of the top of the port side of the vertical stabilizer, it's supposed to be there:
Also don't file flat both hinge arms of the lower speed brakes:
Finally today when I went to add the wings to the fuselage I found they would not fit around the wheel wells. I eventually had to pop the inner wells free from the lower fuselage and glue them directly to the inner wheel wells already installed in the wings:
This allowed me to install the wings onto the lower fuselage which I had happily NOT glued to the upper fuselage yet:
Now it all went together:
Then I had to cut back the tab under the engine bulkhead as it didn't want to fit between the wheel wells. I cut it a bit shorter too:
Whew! But it's coming together!
Posted: Sunday, January 10, 2016 - 12:11 PM UTC
Nice progress, Michael.
Looking forward to see more
SteveAndrews
KitMaker: 629 posts
AeroScale: 489 posts
Posted: Sunday, January 10, 2016 - 05:09 PM UTC
Hi Michael
Thanks again for your post on the Italeri Mirage 111c thread. I thought I'd drop in and take a look at your progress.
First let me say wow. You're moving ahead fast and your kit is coming together nicely. It gives me hope!
That Mig 21 looks tempting too, and I'll be interested to see how the kit compares.
Persevere with the Mirage, I'm sure she'll be worth it in the end.
Happy modelling.
Steve
KelticKnot
KitMaker: 768 posts
Posted: Thursday, February 04, 2016 - 05:38 PM UTC
Hey Michael, just to put your mind at ease that you're not alone i've started my Lancaster. I'll put the general progress updates here but i've started a separate build log as i fear this may be a marathon!
Jesper, the challenge is on!
Posted: Thursday, February 04, 2016 - 06:15 PM UTC
Peter, great to see you get started! You will have a head start as I will be a month or so before I get started.
I will get there, so watch your six
Lakota
#123
Posted: Sunday, February 07, 2016 - 04:58 AM UTC
Howdy Y'all
I think I will drop out of this campaign. I took my F4U-1D to the club meeting and left it in the car overnight. My car was broken into & they took the Corsair along with a bunch of other stuff.
It's a great idea for a campaign but I think I'll pass. I'll be watching everyone's builds for this campaign.
Take care,
Don "Lakota"
Posted: Sunday, February 07, 2016 - 05:26 AM UTC
Crap Don, that totally sucks! Good luck with all the insurance crap and I hope they get the jerk.
Posted: Sunday, February 07, 2016 - 12:32 PM UTC
Tough luck, Don. Hope the insurance will cover it.
Lakota
#123
Posted: Sunday, February 07, 2016 - 04:00 PM UTC
Thanks Guys! I have a lot of leg work to do today because of the break in.
Take care,
Don "Lakota"
Posted: Saturday, February 13, 2016 - 11:06 PM UTC
Half done! The Italeri 1/32 Mirage IIIC in 1967 colors of 101 Tayeset, IAF:
Hopefully soon to appear as a build feature here on AeroScale. Got a couple of other things to finish up before I tackle the MiG-21. But it's only February!
Posted: Monday, February 15, 2016 - 10:58 AM UTC
Looks great, Michael!
Xirrcom
Gdańsk, Poland
KitMaker: 92 posts
AeroScale: 90 posts
Posted: Wednesday, February 17, 2016 - 06:38 PM UTC
Anybody interested to pair-up for this classic clash?
Opting for the 1/32 scale.
