Well got some bench time on the kit this weekend (gotta love long weekends
Biggest issue so far is the cockpit and cabin has no alignment points on the inside to lock it into position, making good alignment difficult. Probably not a major issue IF you are not going to have the cabin door open but if you are, things (roof and floor) need to lined up before the body halves are glued together or gaps will be obvious. Figuring out best fit and way to proceed has been taking most of the time.
I have also been working on adding in some under floor details that are obvious through the lower front windows.
Also removed the right side cockpit door to replace with new version from the Skunkworks extras.
