Tiny Wheels and Tires
Marc2109
Ohio, United States
KitMaker: 28 posts
AeroScale: 26 posts
Posted: Tuesday, December 30, 2014 - 09:30 PM UTC
I used a circle template on my 1/72 scale Gladiator wheels. My approach was to paint the tires first, then mask them using the circle template, then spray the hubs. I got lucky that there was a small circle that pretty much fit. I don't have a way to cut tiny circles to make a mask, my circle cutter doesn't go that small.
Does anyone have an easier way to do this?
Is there a tool that will allow me to cut smaller circles of masking tape?
What do you do?
Antoni
KitMaker: 574 posts
AeroScale: 573 posts
Posted: Wednesday, December 31, 2014 - 03:06 AM UTC
One of those punches for punching holes in leather belts and such like.
raypalmer
KitMaker: 1,151 posts
AeroScale: 985 posts
Posted: Wednesday, December 31, 2014 - 03:41 AM UTC
Silly putty or blu tack over the hub. Although I rarely feel it necessary to not just brush the tires.
KitMaker: 2,395 posts
Posted: Wednesday, December 31, 2014 - 04:05 AM UTC
That's what I use, make sure you have a piece of hard wood as a backer.
KitMaker: 6,702 posts
AeroScale: 5,998 posts
Posted: Wednesday, December 31, 2014 - 05:50 AM UTC
Put a piece of masking tape on the wheel and burnish it into the groove between the tire and wheel with a dental probe or pin. Eventually you'll wear through the tape at the border between the wheel and tire. Then simply pull up either the outside or inside part and paint. Replace the bit you pulled up (parking it on waxed paper is a good way to keep it sticky) once the paint is dry and paint the bit that was previously masked.
Marc2109
Ohio, United States
KitMaker: 28 posts
AeroScale: 26 posts
Posted: Wednesday, December 31, 2014 - 06:30 AM UTC
That sounds like a great tip!!. Don't need to worry about cutting a circle for that!! Thanks so much!
Marc2109
Ohio, United States
KitMaker: 28 posts
AeroScale: 26 posts
Posted: Wednesday, December 31, 2014 - 06:31 AM UTC
Good tip! I'll try to find one. Can you adjust the size of the hole it makes?
Posted: Wednesday, December 31, 2014 - 06:46 AM UTC
Marc you buy a set with different diameters ,they are not adjustable.
Do a web search but make sure the set is made of good quality steel, cheap ones are made from mild steel and are not durable.
KitMaker: 9,433 posts
AeroScale: 7,295 posts
Posted: Thursday, January 01, 2015 - 09:08 PM UTC
Marc,
Most of the time I use the method that Jessica suggested.
I prime then paint the wheels. Then I mask with Tamiya tape as it's generally thinner then most other masking tapes, and once detacked, won't pull paint off when you remove it.
Then I burnish it down with a toothpick. A few more passes with the toothpick works it way right through the tape.
Then I airbrush the tires Nato Black, and remove the tape. and apply a few washes to the treads.
Marc2109
Ohio, United States
KitMaker: 28 posts
AeroScale: 26 posts
Posted: Thursday, January 08, 2015 - 02:50 AM UTC
Thanks Joel that looks great. Now when you say burnish it down, do you mean to rub the point of the toothpic around the rim until it wears through?
Marc2109
Ohio, United States
KitMaker: 28 posts
AeroScale: 26 posts
Posted: Thursday, January 08, 2015 - 02:51 AM UTC
Thanks I am on the lookout.
Marc2109
Ohio, United States
KitMaker: 28 posts
AeroScale: 26 posts
Posted: Wednesday, January 14, 2015 - 02:06 AM UTC
I gave that a go, but my edges don't look smooth like yours, mine are kinda fuzzy and un-even.
