Stripdown
nvitaly
Beersheba, Israel
KitMaker: 2 posts
Posted: Wednesday, April 16, 2014 - 10:35 AM UTC
Could you suggest me how is right to build from photo-etched details?
DH-2 1/48 Eduard's kit.
To glue....?
KitMaker: 6,725 posts
AeroScale: 6,021 posts
Posted: Wednesday, April 16, 2014 - 11:47 AM UTC
You may use epoxy or Superglue (cyanoacrylate). If you're feeling really brave you can solder the brass parts together. That will take great care and a good heat sink.
KitMaker: 9,688 posts
AeroScale: 7,313 posts
Posted: Thursday, April 17, 2014 - 04:44 AM UTC
Welcome to Aeroscale.
To attach PE parts I've struggled at times with extra thin CA glue. I tend to use regular or even thick these days, and now use an accelerator, which really has helped. At 1st I just sprayed it, but it makes a mess, and at times has left a residue. Now I "pump" some into a plastic jar led, then apply with a brush. Works nicely & neatly for me.
5 min epoxy on larger parts works well.
nvitaly
Beersheba, Israel
KitMaker: 2 posts
Posted: Thursday, April 17, 2014 - 09:10 AM UTC
Hi, Dears!
Thanks for your fast and prompt reply!
Actually I've glued with cyanoacrylate the wing, but it is NOT perfect... And also continue to detach even after glueing...
It should to be soldering, but so delicate and thin...???
