Acrylic paint removal
Berwickboy
KitMaker: 447 posts
AeroScale: 384 posts
Posted: Wednesday, February 05, 2014 - 09:41 AM UTC
HELP! Is there any method one can use for removing dry Acrylic paint from a model? I have serious reservations about one of my builds and other than completely rubbing it down, which I would not wish to do, I am stuck.
Thank you in advance
Grauwolf
#084
KitMaker: 2,202 posts
AeroScale: 90 posts
Posted: Wednesday, February 05, 2014 - 10:35 AM UTC
A good soak in WINDEX glass cleaner will remove acrylics.
Check on the paint, when you see it has started to dislodge,
scrub gentle with an old soft toothbrush to get into recessed
areas.
Joe
JClapp
#259
KitMaker: 2,221 posts
AeroScale: 1,681 posts
Posted: Wednesday, February 05, 2014 - 11:03 AM UTC
91% isopropyl alcohol is another excellent paint stripper that won't eat styrene.
Berwickboy
KitMaker: 447 posts
Posted: Thursday, February 06, 2014 - 08:04 AM UTC
Thank you for the advice, I will try and report back
Berwickboy
KitMaker: 447 posts
Posted: Thursday, February 06, 2014 - 10:45 AM UTC
I tried it on a drop tank using Mr Muscle Window and Glass with vinegar (which is what I had to hand) and it works. Thank you for the help once again. Now to strip my Airfix group build F-84
badwolf
KitMaker: 78 posts
AeroScale: 74 posts
Posted: Monday, February 10, 2014 - 09:10 PM UTC
Another good one that should strip most paints from models etc, is Mr Muscle Oven cleaner the one which comes in an aerosol can,
spray over the parts you want the paint off and stick in a plastic bag, depending the size, layers of paint, new or old paint, it can strip paint from an hour to over night,
I have even used Caustic soda on models, read instructions first and alway wearrubber gloves and eye protection, for plastic models you only need to mix this in a weak form, [it gets hot and will melt plastic if you mix it strong, for unblocking drains that type of use], leave in a bucket etc, an hour or so later, rinse off with clean water
