cleaning brushes used with Klear
chris1
Auckland, New Zealand
KitMaker: 931 posts
AeroScale: 478 posts
Posted: Friday, October 11, 2013 - 11:05 AM UTC
Sorry to Bug you guys again,
I've just bushed on 2 coats of Klear floor polish (old formula)
Are there any tricks to cleaning brushes.Or will straight water and detergent do.
TIA
Chris
KitMaker: 6,702 posts
AeroScale: 5,998 posts
Posted: Friday, October 11, 2013 - 11:32 AM UTC
Straight water should do if it's still wet. If it's gone dry, try soaking the brush in window cleaner.
chris1
KitMaker: 931 posts
Posted: Friday, October 11, 2013 - 12:14 PM UTC
Thanks Jess,
But Do u ever sleep????
It's 1.14pm here. it must be night time where you are?
CB
Robbd01
#323
KitMaker: 734 posts
AeroScale: 210 posts
Posted: Friday, October 11, 2013 - 12:52 PM UTC
And if you have really hard stuck on clear just let them soak in Ammonia cleaner. Ammonia is also good if your clear coat for some strange reason starts to turn white on you which has happened to me. I have the pic's
Posted: Friday, October 11, 2013 - 01:20 PM UTC
Thanks Jess,
CB
It's early evening here on the Left Coast of the giant rock which sits between the Atlantic and Pacific.
KitMaker: 9,444 posts
AeroScale: 7,295 posts
Posted: Monday, October 14, 2013 - 03:54 AM UTC
I use a 2 part cleaning method:
1-Windex or off brand window cleaner with Ammonia.
2-follow with a cleaning of running water.
chris1
KitMaker: 931 posts
Posted: Tuesday, October 15, 2013 - 06:35 AM UTC
Thanks for your response
chris
Biggles2
KitMaker: 6,866 posts
AeroScale: 116 posts
Posted: Monday, November 11, 2013 - 03:05 AM UTC
If you use an Aztek (as I used to) I found Future would creep back through the opening for the air. The Future would build up and prevent the snug fit around the projecting metal pin (air valve). When Future builds up and dries in small areas like this , you have to pick at it with a needle point, or some such tool to emove it. This would happen no mater what, necessitating stripping down and cleaning although Aztek warns against opening the airbrush. I since switched to Iwata where cleaning is faster and easier, and the gun works first time, every time!
