| Subject: High Planes Mirage IIIC |
 | Magnus Fridsell magnusf |  | Location: Stockholm, Sweden Member Since: May 02, 2006
Posts: 596 entire network,
569 this site
| Posted: Wednesday, October 07, 2009 - 12:08 AM UTC |
This will be a Mirage IIIC in air defence blue for this campaign: La Marseillaise. I have built one of these before so I know what to expect  ...  Box art is as usual a bit odd...  Three sprues of blue plastic, a bag of nice resin parts and a very clear canopy. Only one so be sober and alert while cutting it!  Decals for several French machines in either natural metal, air defence blue or desert (Djibouti based aircraft) schemes. No Israeli options in the box but such decals are easily obtained from other sources!  A close-up of the resin parts. Not really Czech quality but perfectly adequate! A resin engine outlet had been welcome as well, all later Mirage versions from High Planes have resin engines but the Atar 9B of the IIIC kits is injected. I have been working a bit on and off on this one during the last few weeks, here is the result so far:  Finished instrument panel (hugely magnified...).  The Interior. Side consoles could have been better detailed but a paintbrush can do marvels as well, especially under a closed canopy!  Biggest problem with all High Planes models I have built is usually closing the fuselage. Plastic is rather thick and interior parts are often a bit on the large side. The fuselage sides have been thinned down as much as I dared, even then I had to file out a recess from the cockpit (hidden from view by the ejection seat later) to be able to get it all to fit. I have also added a bunch of lead shot to avoid tail sitting.  Everything buttoned up and set aside for drying overnight! I wonder if I can finish this one in a month...  Magnus |
Current project: Airfix Spitfire twins!
Target for 2010 is six finished models, six still to go! | |  |
| HIDE SIGNATURE AREAS |
 | Tim Prosser Tango-India-Mike | Location: Western Australia, Australia Member Since: August 31, 2009
Posts: 88 entire network,
79 this site
| Posted: Wednesday, October 07, 2009 - 02:20 AM UTC |
Aha! Another one I'll be keeping an eye on, Magnus...I have the IIIO kit here, which is going to look beautiful in the bare metal finish our RAAF Mirages wore in the 1960s. Of course, I remember them camouflaged in green and grey in the '70s (and they were still beautiful), so I guess I'll have to buy another kit eventually!
In the meantime I'll just watch you build yours so I know what I'm in for! Masses of flash and rough edges on the one I have here, as I can see on yours too, but there's an absolute gem of a model amongst it all...that's for certain. I love High Planes kits!
Tim. |
| "Never call it a plane, Bader...it's an AEROplane" | | |
569 this site
| Posted: Thursday, October 08, 2009 - 08:16 AM UTC |
Tim! You seem to know the trick already: careful cleanup and dry fitting are the keys to success! Without it you will simply not be able to glue many of the parts together! After a bit more than an hour at the building table tonight:  This is the make it or break it of this kit: the wing leading edges! The Mirage has very characteristic drooped leading edges that have been included in the kit but there is lots of excess plastic as well. The top wing halves need to be carefully thinned using a curved scalpel blade. The lower wings are easier to thin with a file.  Rear end thinned and sanded round, profile adjusted with sand paper as well. The separate fin have also been attached.  One piece of French-looking delta wing!  Magnus |
 | Björn PolarBear | Location: Skåne, Sweden Member Since: February 23, 2005
Posts: 755 entire network,
564 this site
| Posted: Thursday, October 08, 2009 - 09:03 AM UTC |
Ooaah! Mirage IIIC!!! My favorite! Looking forward to the blue scheme! I'd actually would love to build one myself! Do you know which FS matches the blue-grey? I've searched, but haven't found any info. I actually received the amazing SMS resin detailing set for the Eduard Mirage IIIC in 1/48 by mail today (yes, I will cross the line into the BIG scale). Given my current building pace, I do not believe that I will be able to enter her in the Marseillaise campaign. But then there's the Aluminium campagn... and the there's the Aces High Two campaign... Somehow, I plan to get myself a nice little ribbon with this kit. You know what they say, blue is for boys and...  As always, bon chance!  // PolarBear |
569 this site
| Posted: Thursday, October 08, 2009 - 06:01 PM UTC |
Thanks for the profile but I think I'll avoid that one. I have the story and a few photos of it in the DTU book on the Mirage IIIC and in reality the pink was painted on rather roughly. It didn't stick very well either, the natural metal area in front of the windscreen had to be wiped clean in order not to get pink paint all over the canopy when flying. And yes, it did fly - once! As for the colour choice for blue Mirages, High Planes states FS 35164 (about PRU Blue). I think it looks a lot brighter than PRU blue but that's me... Another possibility comes with the Hasegawa Mirage F.1C that suggests a mix of Gunze paints: 80% H75 10% H54 10% H1. (For the mathematically inclined: yes I have checked that it adds up to about 100 %  ). That Mirage kit is also an easy way to get a Matra R530 for the centreline pylon. Probably mostly carried for deterrent or possibly centre of gravity reasons since reliable sources state that it was almost impossible to hit anything with it! I'll try to keep you entertained for a month and so, and good luck with your big scale Mirage Björn!  Magnus |
569 this site
| Posted: Friday, October 09, 2009 - 09:06 AM UTC |
Some more work on the fuselage. The intakes are another potential trouble area on these kits. On my first IIIC I cut off the "wing extensions" and added them to the intake halves. That way I didn't have to do any internal sanding but it was quite fiddly to assemble them and keep their shape at the same time. Enough of complaining and on to the model:  Splitter plates added using the thinnest plasticard I could find.  The intakes. Plates will be trimmed to size when all is dry!  You see the problem... There should be an "intake bullet" in the opening that severely restricts what can be seen, that will help a bit. On my first IIIC I even made intake trunking that extended halfway down the fuselage. No one has seen any of it after the bullets were installed  !  Magnus |
 | Rowan Baylis Merlin
Managing Editor
|  | Location: No Regional Selected, United Kingdom Member Since: June 11, 2003
Posts: 10,027 entire network,
6,460 this site
| Posted: Friday, October 09, 2009 - 09:51 AM UTC |
Hi Magnus When I saw "High Planes... ", I thought it has to be you! That resin seat looks very decent indeed. As always, your builds are hugely inspiring - great subjects, unusual kits, and informative solutions to the problems along the way... what more could one ask for?! All the best and keep 'em coming! Rowan |
(formerly "Porky")
BEWARE OF THE FEW...
As I grow older , I regret to say that a detestable habit of thinking seems to be getting a hold of me. - H. Rider Haggard | |  |
564 this site
| Posted: Saturday, October 10, 2009 - 08:37 AM UTC |
Impressive work, Magnus! I'm amazed that you have the stamina! I thought the AML Mirage II kits were difficult, but that was before I saw what you have to cope with! EDIT: I found this decent walk-around that might come in handy. Unfortunalely, the seat is rather stripped! http://www.cocardes.org/models/articles.php?lng=fr&pg=962 I still need a good colour photo of the seat. Any leads? Bon chance! // PolarBear |
569 this site
| Posted: Sunday, October 11, 2009 - 08:39 AM UTC |
Rowan! Glad you like my blogs and choices of kits! The blogs are as much for myself as for everyone else, I keep them as diaries of my builds that are fun to visit a few builds later. "High Planes" is just the tip of an iceberg, you should see my stash  ! Björn! As usual, things aren't as bad as they seem. Seat is black with black details  . My favourite reference for what's under the hatches of a Mirage is Verlinden's lock-on on Belgian Mirages. I'll PM you on the subject of seats! And thank's for the link!  Atar 9B. Fun engine with the eyelids, doesn't really look like anything else!  As I wrote earlier: Biggest problem is all the things that go inside and engine is no exception. It is much bigger than the hole in the rear end of the fuselage and I don't feel like sanding away all that excess plastic. Note also that wall thickness is about as uneven as this photo is out of focus and that's a lot  !  Fixing the engine meant sudden death for a pen of suitable diameter. It also adds some very inaccurate but interesting internal detailing!  Intakes after sanding. Not bad or what do you think Björn?  Magnus |
569 this site
| Posted: Monday, October 12, 2009 - 06:35 PM UTC |
Did the last of the wing-fitting yesterday so now we have a complete delta fighter!  Magnus |
569 this site
| Posted: Thursday, October 29, 2009 - 09:38 AM UTC |
Back again two weeks later! It has been filling-and-sanding party lately...  The small dorsal fin has to be added from plastic card. A sketch is provided in the instructions.  I realised that the nose wasn't round in section, it was seriously flat on the lower side. I built it up using Tamiya putty that will be sanded to section tomorrow.  Delta fighter!  Magnus |
 | Drabslab drabslab |  | Location: European Union Member Since: September 28, 2004
Posts: 681 entire network,
422 this site
| Posted: Thursday, October 29, 2009 - 08:57 PM UTC |
now this is some serious "back to basics" modelling very interesting, i love it |
Building kits is only the tool, what counts is the friendship it brings
569 this site
| Posted: Thursday, November 12, 2009 - 09:03 AM UTC |
I haven't forgotten the Mirage altogether... With the seat painted, the only thing to do before closing the canopy is adding the HUD glass.  I primed the seat white and painted it "backwards" this time, starting with the details and finishing with the black. Not a bad idea since it made it so much easier to get the paint to cover.  Verlinden "Lock-On" on Belgian Mirages has lots of detail photos including several photos of the seat and is of great help when it comes to painting!  Magnus |
569 this site
| Posted: Saturday, November 14, 2009 - 10:11 AM UTC |
Seat installed and cockpit finished!  Canopy glued using epoxy. I use a glue called "J-B Kwik" that sets in a few minutes and it doesn't set "rubbery" as many other epoxies making it possible to sand. I often use it as a kind of filler as well around canopies.  Magnus |
564 this site
| Posted: Thursday, November 26, 2009 - 07:32 AM UTC |
Hi Magnus! I truly enjoy following your build! The horror of the 1/72 Mirage kits, the struggle to get everything in shape, and the beautiful results that follow... BTW, guess what I'm building!?  More pictures will be posted on the Aluminium campaign thread! Cheers! // PolarBear |
569 this site
| Posted: Thursday, November 26, 2009 - 07:36 AM UTC |
Hi Magnus!
I truly enjoy following your build! The horror of the 1/72 Mirage kits, and struggle to get everything in shape, and the beautiful results that follow...
Anyone can see that it's a Big Bird Björn! BTW, the Mirage ain't dead, just hibernating for the moment (look, a bear-connection...)  Magnus |
564 this site
| Posted: Thursday, November 26, 2009 - 07:58 AM UTC |
It is indeed a BIG bird (see there - a "Magnus"-connection!). 1/48, no less. My first! Cheers! // PolarBear |
