Cleaning brushes
Belt_Fed
KitMaker: 1,365 posts
AeroScale: 42 posts
Posted: Sunday, September 21, 2008 - 08:43 AM UTC
When using a liquid glue and using a brush (not the one they give you in the cap), whats the best way to clean it?
Also, how do you clean your brush after using Mr. Surfacer 500?
buggalugs
KitMaker: 135 posts
AeroScale: 115 posts
Posted: Sunday, September 21, 2008 - 09:39 AM UTC
Hi Jon, what works for me with the liquid glue (certainly the Tamiya type) is that I just take the brush out of the glue when I have finished using it, give it a wipe with a tissue or something, and let it dry. It dries rock hard - you can't bend the bristles on the brush - but the next time you want to use the brush, just stick it back in the glue container and, hey presto, it softens almost instantly and you can use it like normal. Sounds weird but it works very well.
With Mr Surfacer, I use Tamiya lacquer thinner to clean the brush. It works OK, but I'd be happy to hear if anyone out there has a better method!
Hope this helps, cheers Brad
Belt_Fed
AeroScale: 42 posts
Posted: Sunday, September 21, 2008 - 10:05 AM UTC
thanks for the advice on the liquid cement. i hear a similar technique works for removing future.
Also, my LHS doesnt supply Tamiya Lacquer thinner, so i am going to need another method
05Sultan
#037
KitMaker: 2,870 posts
AeroScale: 258 posts
Posted: Sunday, September 21, 2008 - 10:35 AM UTC
Future can be cleaned from brushes with warm water only or if you want to be absolutely sure,use Windex or any other cleaner that has ammonia in it.
If Tamiya lacquer thinner works for Mr. Surfacer,then a generic lacquer thinner from your local hardware/paint store will work just fine.
Belt_Fed
AeroScale: 42 posts
Posted: Sunday, September 21, 2008 - 12:01 PM UTC
my thanks to all that helped!
KitMaker: 6,739 posts
AeroScale: 6,147 posts
Posted: Sunday, September 21, 2008 - 12:44 PM UTC
Nail polish remover works well for cleaning mr. surface from brushes .
Anmoga
Spain / España
KitMaker: 440 posts
AeroScale: 13 posts
Posted: Sunday, September 21, 2008 - 09:02 PM UTC
You can use acetone to remove Mr. Surfacer. Nail polish remover is odorless acetone.
