Clear Instrument Panel Question
michaelbay
KitMaker: 3 posts
Posted: Sunday, August 31, 2008 - 05:33 PM UTC
I'm in the process of building Accurate Models 1/48th scale SBD Dauntless. A fine model, but I'm a bit confused on one bit.
The instrument panel is a large piece of clear plastic. The instructions say it should be painted flat black, leaving the dials clear. A decal is supposed to be applied to the rear, the colored bits to be seen through the clear dials.
My question is this: How am I supposed to paint it without painting the dials? They're tiny, and I can't image its feasible to mask them.
Any thoughts?
Posted: Sunday, August 31, 2008 - 07:46 PM UTC
Hello Michael
Try liquid mask (like Humbrols Maskol) applied with a tooth pick
HTH
Posted: Sunday, August 31, 2008 - 10:42 PM UTC
Hi Michael.
One option would be to first dip the panel in Klear. Paint the panel by using a very thin mix of paint. 70% thinners/30% paint. Touch the loaded brush against the panel and capilary action will pull the paint around the raised dials. The smooth surface of the Klear will help the paint run.
If you use thinned acrylics its very easy to strip the paint off and try again if your not happy. Naturally, you'll need to apply the decal after youve finished painting the panel.
Hope this helps.
Posted: Sunday, August 31, 2008 - 11:11 PM UTC
Hi again
Nigels post gave me another idea.
The instrument holes could also be drilled out. IIRC there are two decals: one "backwards" to be attached to the clear part from behind and one printed in the "right" direction. You could attach it to a white piece of plastic sheet and cut out the dashboard shape. Paint the clear part, drill out the holes glue the plastic sheet from behind (white glue), add a drop of Futur/Klear in the instrument faces.
SilverDollar
KitMaker: 10 posts
Posted: Sunday, September 07, 2008 - 08:15 AM UTC
Hi again
That's the way I do it also. It gives a much better result that the box stock solution.
